Graphite Tape
  • #31
    Originally posted by Artyom View Post
    Hello. Can you tell me if it is possible to solder the outgoing conductor to the conductive tape? or how best to attach the outgoing wire to the tape?. Thank you.
    A soldering iron easily melts the tape, but with a lot of care and a lot of flux I have successfully soldered a thin drain wire to the tape. However, all of the tape I have bought is also conductive on the adhesive side so the easiest solution is to just tape the drain wire to the shield.
    • #32
      You can try the Rose alloy...
      • #33
        Thank you. And what is this tape? what does electrical conductivity consist of and due to what? Is shielding the VLF detector windings suitable?
        • #34
          Really.. I hadn't even thought about it) Thank you.
          • #35
            https://www.amazon.com/Shielding-Con.../dp/B0BXXK7XJX
            Also available on AliExpress.
