What are the exact functions of the values in the coils?
What is the exact purpose of mH, LP, RP, Q, X, what are they used for?
There is something I don't understand, let's say the detector I am currently using has
10 turns 0.40mm tx coil
50 turns 0.20mm rx coil.
But if I take the coil winding number from a different detector and use it on my own detector, unfortunately the performance deteriorates.
Note: If it is a resonant circuit, we change the resonant capacity according to the coil.
Let the coil of the different detector be like this;
40 turns 0.40 tx coil
180 turns 0.20 rx coil.
coil values are random.
The values change in both tx and rx coils, what should I understand from these, which value means what and what should be done for this. Should the RX input filter change according to TX or is there a different ratio, proportion, I have a lot of question marks in my mind about this.
