NOW IT WORKS !
Hi all,
I think I've solved the problem in a cheapy way. My bandido seems works now.
What I have from tests in disc mode using a near-to-extrem setting of the disc pot:
- 1 eur coin at about 30cm
- 2 eur coin at about 32cm
- 1 half crown (diameter 32mm) at more than 35cm
- 1 small gold ring (1.5grams) at 24-25cm
- 1 copper cilinder thick 0.5mm, diameter 46.5mm, height 12mm at 42cm
- 1 silver coin (diameter 30mm) at 22cm
That seems pretty good... and like what I expect from Bandido.
All tests where made with fast object movements relative to the coil, tring to simulate
1m/s swings.
It sound also with iron (and rarely with steel) sometimes...but at few cms and with big masses (tools, hammer...).
So it's not perfect discrimination in my unit.
Question: have bandido total disc vs IRON ? I don't know.
Maybe it depends only of capacitors used.
Now the solution, I've used:
- eliminate as much noise as possible
Noise is really subtle.
I've done using semi-encapsulation of some part of the circuit board using a thin aluminum
sheet (insulated with plastic foils) shaped to cover upside of components/pcb. On the copper-side
I've used another PCB (single side copper downside), not etched, connected to circuit pcb using
screws and plastic spacers to give 4mm of distance from circuit copper-side.
Both metallic shields connected with a wire to a unique GND PCB trace.
This cutted out more than 95% of 50Hz noise...and now I have two symm signals at inputs of
comparators (IC8a-IC8b).
This way I get output nearly flat, at a small negative voltage, that rise when an imbalance
occourrs thus giving the audio signal to show-up.
I've noticed that bandido circuit is very sensitive to external noise also if one use (like I did)
fiberglass pcb...using solvents to remove flux after soldering etc...and that's expecially true for
the disc signal path starting at c20/c21.
Only thing to solve and avoid big troubles is Faraday shielding sensitive parts.
So, other good solutions can be using Gary's pcb with a huge upper GND layer and RF guards or use the germany
group pcb or another that have a good, wide gnd screen.
I think that Gary's PCB is very good for testing but, if one can do, to have the best he must add a second
upper layer of copper (double side) to give it a good GND plane and maybe also built in "jumpers".
Unfortunately, I can't do double or multiple side PCBs at this time... so I'll continue with metallic shields,
at least for now.
Other easy solution is insulate everything in a metallic box connected to GND - if a removable cover
present is easy enough to open and connect probes etc for testing.
IVCONIC, TRY SHIELDING AND LET ME KNOW.
Thanks again to all.
Best regards,
Hi all,
1m/s swings.
at least for now.
Best regards,
