I am in the process of building a submersible probe for my Garrett Sea Hunter Mk II. I am getting conflicting information on which pins are the active pins on the coils and housing.
I was told by Garrett (newbie in Tech Support) that there were only two active pins on the Coil. When I put the MM to the to the pins he suggested I get no Resistance reading. But when I put the probes to the oposite pins, I would get a resistance on the 8" mono coil of 1 ohm. But this would happen on both sets indicating that all 4 pins ARE active. My question is, are there two seperate coils in the 8" mono and what are the correct pins to use for hooking up the probe?
I have not taken apart a Garrett Coil for the SeaHunter, but I am having trouble figuring out which pins are the right ones to conect for the probe.
Any suggestions?
Robert in SC
Any suggestions?
Robert in SC
