SD coils
Hi gef12,
Yes Shield material. There are different methods and materials to use. Tried a few different methods but settled on the following type of shielding. I use an enamelled copper wire shield which will not be picked up by the detector. When the current to magnetic field of the coil is abruptly turned off the coil magnetic field collapses and induces an eddy current in the target material. It also induces an eddy current in the coil screen and the effect will depend on the type of screen employed. The signal received by the detector will then be a composite of the target signal, screen signal and residual ground signal. The idea is to ensure that the screen signal does not mask the target material signal.
I fabricate the shield as follows:
Use thin yellow polyester tape 19mm wide (available from RS Components) and lay approx 30 strands of 0.2mm enamelled copper wire length wise along the tape. ( sticky side). The end result will be about 3 m of tape with 32 lengths of enamelled wire afixed to the tape roughly evenly spaced across the 19 mm width. I then layer another layer of polyester tape on the wire side of the fabricated tape so there is no sticky side. I have a jig to help me do this as it is time consuming.
I then wind the screen spiral wound leaving a gap of 10 mm between the turns onto the coil. I make another tape 15mm wide with the appropriate number of wires and wind this on the coil to fill in the gap.
The other way is to use the 19mm tape and spiral wrap with a slight overlap so the screen fully covers the coil. A final layer of polyester tap is wound over the total shield to hold all in place.
This screen works because the wire in the screen is insulated from adjacent runs, small wire diameter so the eddy currents induced are minimall with no consolidation of the eddy currents in the screen.
Note that one end of the tape is insulated so I usually cut of clean with side cutters and insulate with some polyester tape. The other end is the one you connect to the shield of the coaxial signal cable.
So thats about it?.
Stefan
Hi gef12,
So thats about it?.
Stefan
