I realize this is a very simple question to those here but it might help me understand the RX part of the coil signal.
Is it the responding Eddy current from the target thru each turn of the coil, where each intersecting point generates a small signal that accumulates to make the full RX signal? Put another way if a coil had 6 turns then the eddy current would only have 6 points to induce a signal, where a 30 turn coil has more lines to intersect and induce more signal.
If this is so then does any of the loops null out when it collides with the signal from another loop or does this signal look like a train where each car is a(analog version of data packet) unique signal waiting to arive at the PI board or do they add up to one signal.
Or is this totally the wrong way of understanding the RX signal to the PI board.
Thanks Wyndham
Thanks Wyndham
