I have a Tesoro 10" concentric coil which needed repairing. I opened the shell and made the rewiring of the cable to the coils. Hopefully I was able to recognize where each wire of the shielded cable was connected to, because a bit of plasting was still in place. Then I welded also the wires in the connector as in the origin and as it is shown in the picture I found here. So:
Grey pin 4, Purple pin 3, shield pin 5, Orange pin1,
Inside the coil shell I connected purple and screen together, then to the side of each coil (RX & TX) and to the wires that goes to the conductive paint surface for the screening. I think everything is correct, in fact if I measure on the connector I get:
23 ohm and 6.16mH between 3 & 4
24,5 ohm and 6.04mH between 5 & 1
0,2 ohm beetween 3&5 (cable screen resistance)
The coil is working, not extremely well, since it's not better than the 8" coil but works, the problem is that when I touch any metal parts of the MD (TEsoro Conquistador) like the switch or the connector for example, the threshold set in all metal mode decreases (disappears), while touching in Disc mode produces most of times a false signal.
I can't guess the reason. Notice that this happens even when the two half shells are closed one over the other!
Any tip?
Stefano
Any tip?
Stefano
