The generator coil consist 35 turns .55 and the recieve coil - 130 turns 0.2.
The wire in the generator is aluminium. It doesn't matter what size is the coil as long as you keep the exact number of turns correct. The freq can be adjusted on the board with the 1uF Cap. Good luck!
"...It doesn't matter what size is the coil as long as you keep the exact number of turns correct...."
Say what??? So it means he should keep same number of turns no matter if coil is 4" or 10" in diammeter??? And Relic Hawk will perform the same??? Hah,hah,hah,hah,hah,hah,hah,hah,hah!!!!!!!!!
