co-axial coils
  • co-axial coils
    could anyone give me imformation on how they are constructed
    Re: co-axial coils
    Frank,
    Coaxial coils are made by stacking 3 same-sized coils in a cylindrical row, spaced slightly apart. Think of donuts stacked 3 high. Coaxial literally means "along the same axis".
    Usually (probably always), the center coil is transmit and the 2 outer coils are receive, and the receive coils are connected out-of-phase. Therefore, they nominally receive the same signal from the transmit coil, but since they're out-of-phase the signals cancel. When you bring a target close to the coils it creates an imbalance in the out-of-phase signals so now there is a net signal at the receiver.
    Coax coils are usually thicker than other coil types. I think the early Garrett VLF detectors used them, as did the C&G 'cat detectors. You can also make the 2 receive coils smaller than the transmit coil, probably gives better ground rejection.
    Carl
      Re: co-axial coils
      Carl
      Many thanks for that imformation.But do you need to null the receive coils,and how do they compare to a DD,and concentric.
      Regards Frank
        Re: co-axial coils
        Hi Carl and Frank,
        A big plus for coaxial coils is that they cancel power line and other low frequency noise.
        Eric.
          Re: co-axial coils
          Yes, they must be nulled. If both RX coils have the same # of windings then they simply need to be equally spaced from the TX coil and connected out-of-phase for nulling.
          Eric is right, coax coils cancel external interference better because both coils are affected equally but oppositely, thus canceling the effect. Compared to concentric and DD, I don't thing the coax gives as much depth unless you substantially space the RX coils, which makes the overall search head thicker. That's because a target will affect the closest RX coil but will also, to a lesser amount, affect the farther RX coil which creates some cancelation. Coils with only 1 RX winding don't have this problem, even concentric coils that have a secondary RX winding since it's a much "weaker" coil.
            Re: co-axial coils
            Thanks Carl
            One further question,how do they handle mineralization compared to the DD
            Regards Frank
              Re: co-axial coils
              I'm not sure. Apparently not as good since I think no one is making coax coils these days. You could try asking Jack Gifford, he's the "G" in the old C&G Technology that made the 'cat series, he now runs Tesoro.
