Coil questions:
A PI coil that has only one winding that serves as TX as well as RX will have an optimal detecting depth about equal as the diameter of the coil.
How does this work with a PI coil with 2 windings, the outer TX and the inner RX. Is the optimal detecting depth now about equal as the diameter of the RX winding?
This is important, because for the shortest delay, the RX winding should be as far as possible away from the TX winding, therefore the RX winding is usually of a smaller diameter than the TX coil.
Tinkerer
Tinkerer
