Gretings, new to the forum and this is my first (probably of many) Questions.
I'm building an HH system on breadboard and have the power supplies, oscillator and coil driver working.
I made a stab at a coil last night using 27 truns (probably 8 too many) of #28 Kynar wire wrap wire. This was taped with yellow transformer (mylar?) tape, then wrapped with spyral wrap and finished with a shield of copper tape (1/8" gap at ends near the leads from the coil.
DC resistance is 4.8 Ohms.
I have access to a HP4193 Vector Impedance meter, but can't make much of the results.
Without shield connected:
26K ohms at 717Khz, phase angle =0 degrees
23K ohms at 700Khz, phase angle = 30 degrees
23K ohms at 738Khz, phase angle = -30 degrees
With Shield:
27K ohms at 673Khz, phase angle =0 degrees
24K ohms at 688Khz, phase angle = 30 degrees
24K ohms at 658Khz, phase angle = -30 degrees
This looks like my resonance is near 700KHz since this is wehre the phase angle passes through zero, so not a bad first attempt, but certainly lots of room to improve.
What I'm trying to understand is how to use the impedance change at 30 degrees to determine the Q of the coil. THe phase shift of 30 degrees with a frequency change of 17Hz out of 700 seems like a fairly quick drop off, but I normally don't work with rf so I'm not sure.
Thanks.
With Shield:
Thanks.
