I have a very basic question about coil shielding. From what I have read here and other forums, the shielding is sometimes a spiral wrap with gaps left open in the winding. Does the gap have anything to do with the response from the target. It almost seems as if it might be a filter to only allow the weak target signal to get thru.
If this is anywhere near correct, If this is so, shouldn't the shielding gap be designed for a certain pulse response? How about a shielding tape that is perferated with a certain dia holes along the tape and the coil wrapped solid. It seems from by lack of tech training POV that the coils shielding could be the make or break of a coil design. It seems you want the most signal response but not the ground chatter that might come in with the target signal. Or is it that the coil is so overpowered by the rx signal that the shield works as a brake or governor for the coil.
If anyone has a thought on this, thanks for the time Wyndham
