Coils
  • Coils
    Hello people!
    Does anyone have any info on the (VLF)pinouts
    of the search coils of the larger manufacturers?
    Im looking for pinouts of Bountyhunter, Tesoro, whites, Fisher, etc! Why? Because i like to adapt my own design to several of these!
    Aprechiate any info submitted!
    BJ
    Re: Coils
    BJ,
    Try search on #5 and look at 5.02.01 Rick S. The White's GMvsat coil drawing and pic of inside the coil housing.
    Rick S
      coils & pinouts
      In my opinion, the searchcoils best adapted to hobbyist experimentation are the Tesoro Lobo Supertraq and the Fisher CZ coils. Both are single-ended transmitter and receiver with no transmitter resonating capacitor. Eectrically they are somewhat similar, with transmitters somewhere around 1 mH, and receivers somewhere in the range of 10-15 mH. The Lobo loops are balanced for the Lobo of course, about 17.5 kHz, but can be used somewhat outside that range. The CZ coils are balanced in the range of 5 - 15 kHz. Of course these are induction balance searchcoils for VLF use and are not suitable for pulse induction. The CZ coils have lower resistance and therefore higher Q than the Lobo coils, but the Lobo coils are available in wider variety.
      In order to determine the pinout and actual inductance, use an ordinary LCR meter. Determining which end is signal and which is ground can be a little more complicated unless you are able to slip the shell off the connecter and determine wiring by inspection.
      --Dave J.
        Re: Coils
        That was a rather complicated coil, does it
        really perform any better then a well done ordinary pinpoint coil(omega loop type inside)??
        Thanks for the info anyway Rick!
        Reg
        BJ
          Re: coils & pinouts
          BTW, when we are talking about "coil
          resistance" what parameter are we exactly
          talking about? The impedance or the reactance
          or the DC reistance or all together at a
          given frequency?
          I mean the reactance is important in the sence
          of knowing the load for the TX driver amp at
          a given frequency.
          And forgive me for this question, but im used
          to mH mm, inch etc, so what does eg, 26AWG
          stand for?
          26 Automated Wolksvagen in GB?? :-)
          REg
          BJ
            Re: Coils
            BJ,
            The Goldmaster series coils have to be within the design limits for the circuit. The concentric looks complicated, but it is easier than making a DD coil. The info is there on making a coil for the GM series. Good luck.
            Rick S
              Coil pinouts
              Winding, followed by pins (pos,neg), followed by inductance, and finally DC resistance.
              White's Spectrum
              Rx 1,2 36mH 123 ohms
              Tx 4,5 540uH 1.4 ohms
              White's 6B
              Rx 1,2 16mH 35 ohms
              Tx 4,5 1.7mH 7 ohms
              White's DFX concentric
              Rx 1,2 13.8mH 36 ohms
              Tx 4,5 540uH 2.7 ohms
              White's DFX DD
              Rx 1,2 14.2mH 55 ohms
              Tx 4,5 680uH 3.5 ohms
              Tesoro concentric
              Rx 3,4 6.2mH 22 ohms
              Tx 1,5 5.7mH 22 ohms
              Tesoro early Lobo DD
              Rx 1,3 1.35mH 12 ohms
              Tx 2,4 10mH 55 ohms
              Fisher CZ
              Rx 1,2 6.8mH 30 ohms
              Tx 3,4 1mH 2.8 ohms
              Most numbers are based on several coil measurements, including different size coils for a given coil type.
              The White's 6B coils are really easy to find, and come in a huge range of sizes.
                wire gage etc.
                Resistance is measured at DC, or at 1 kHz which is nearly the same thing. Searchcoils are almost always designed so that the AC losses are small compared to the DC losses.
                The AWG system is like decibels. Every increase of 3 in wire gage corresponds to a doubling of wire resistance (a halving of wire cross-sectional area). AWG 18 has a diameter of 1.02 millimeters, and a nominal resistance (annealed copper) of .0209 ohms per meter at 25 degrees C. From that, all AWG diameters and resistances can be calculated.
                --Dave J.
                  Re: Coil pinouts
                  Hmm, it seams that the tesoro lobo RX TX values are swapped?
                  Besides does this mean that those coils you
                  mentioned here is differentially driven and
                  differentially recieved?
                  Or does it mean that all are single driven and recieved and coil ends to separate GND's?
                  Besides,what kind of TX driving is most common
                  a tri/sin funkgen or the "wandering" colpitts?
                  Thanks for the info anyway Carl!
                  Reg
                  BJ
                    Re: Coil pinouts
                    Yes, I probably got the Lobo pins swapped.
                    Far as I know, everyone is driving coils single-ended. Most use basic Colpitts oscillators, some pnp with the coil grounded, some npn with +V on the coil (e.g., White's). This is true for single-freq. designs. Multi-freq use pulse waveforms, probably generated by the micro.
                      What's a omega loop?
                      i've never heard of a omega loop can anyone tell me what that is?
                        Re: What's a omega loop?
                        Yuo can see Magnum project in the site, magnum use "omega" design coil.
                        max
                          Re: Coils
                          Hello
                          Fisher 1210
                          Rx 6,48mH / 15,3 Ohm
                          Tx (1,64mH / 7,7Ohm) + (1,62mH / 7,5Ohm)
                          Fisher 1266
                          Rx 10-10,4mH / 38,2-39,3 Ohm
                          Tx 2,14-2,2mH / 4,7-4,9 Ohm
                          Fisher Quick Silver
                          Rx 6,69-6,7mH / 31-32Ohm
                          Tx 0,945-0,960mH / 3-3,1Ohm
