Coil field collapsing help!
  • Coil field collapsing help!
    Hi Guys,
    this is what I think the problem is -:
    1) Refer to picture : http://img261.imageshack.us/img261/949/coilhelpyb4.jpg
    Theres 3 resistors, and a small diagram to show how this unit is wired. The coil goes to a 20w resistor then i think is further calibrated by the other 3 resistors (? not 100% sure)
    2) The coil must have to collapse at a certain rate for when the sample is taken, in the original circuit I was given, it uses the resistors in the picture at the very top and I haven't got a clue what they actually are!! Can anyone educate me as to what type of resistor this is? they don't look old, just different!!
    But by using these resistors, the original circuit works. The duplicate circuit I have made doesn't ( I used the second ones from the top in the picture) and I've figured it has to be these resistors (because everything else is pretty straight forward). I *think* the resistors Im using are causing the detector to sample at the wrong time(?) because the field is collapsing at a different rate to the original circuit.
    the original unit is a prototype and its resistors are connected as you see them in the picture.
    Werid huh...
    Any help or advice on how to solve this problem would be appreciated!!
    Thanks!
    What circuit / detector are you building, it would help if you told us as I can't believe you need a 20W damping resistor unless you are drawing 10A plus during peak pulse. What sort of depth are you aiming for? I think you're going to need an excavator to dig the holes for you
    Can you post the full schematic here please?
      Sorry for the late reply,
      I don't actually have a schematic, I'm just copying an existing circuit...
      Would you have any idea what the 2w resistors are? are they carbon? ceramic??
      Thanks!
