Hi all,wondering if possible, if I were to disect a 10in sovereign coil, could I spread it's internal parts to make an 20in plus coil without having to recallibrate it,and if not could the same circuit board be used.regards dougy, au.
larger
Originally posted by dougy View PostHi all,wondering if possible, if I were to disect a 10in sovereign coil, could I spread it's internal parts to make an 20in plus coil without having to recallibrate it,and if not could the same circuit board be used.regards dougy, au.
What ? Wanna reuse parts ? Wire also ?
If problem is wire... buy some... it's impossible reuse it cause of epoxy stuff that's employed to fix it in place.
If, instead, you mean the circuit ML put there... you could reuse it.
But, problem is... that ML coils are extremely difficault to replicate well... if you wanna make 20'' I think you must consider it's really hard stuff, expecially when that big monster will fly over soil.
You need much luck...
Kind regards,
