Howdy,
I realize that not enough spacer between the coil shield and coil is a bad thing, but what is the upper limit?
Can one space the shield too far away? I mean, given the limits of the coil housing's volume, of course....though vacuum forming my own coil housing does give me some leeway.
Atm, I have two wraps of electrical tape covered by about .2" Teflon tape (300 feet of PTFE plumber's tape on a 9" x 3" rectangular coil).
I'm using 1/4" x .001" copper tape (used for stained glass window work) in a slightly spaced spiral wrap for my shield (Yes, I know there are other materials, but that's what I have handy).
I stripped the copper tape off of my rec coil (DD) to try a thicker spacer (hence the tef tape). Right now, I can add more tef tape if you folks think I need more....
But how far should I go? Or is this one of those "give it a try, you're on your own" kinda things?
I'd rather not re wrap the shield yet again, if you know what I mean.
Any input on this one?
Curious, GTB
Curious, GTB
