How to approach making a coil for Infinium
  • How to approach making a coil for Infinium
    Hi everyone, I would like to try designing and constructing an 18" round monocoil for my Garrett Infinium. I do not want to damage the unit while trying to accomplish this task. I know there are many different values and parameters to take into account. I have BB Sailors fast coil article which is very good. So what testing setup do I need in the initial stage of this project without using the Infinium until I get in the ballpark? Thanks everyone and happy building!
    John Tomlinson,CET
    John's Detectors
    John,
    Go to the Garrett web site and look at the technical article that depicts Garrett coils. http://www.garrett.com/hobby/techsup...searchcoil.pdf Note that some mono coils are actually two concentric coils that are close together with separate TX and RX coils.
    Measure the resistance on each of the connector pin-sets. If the connector has 4 or 5 pins and there is resistance between two sets of the pins and the pins are not wired in parallel, that would indicate that two separate coils are being used.
    1. Use tin plated (not silver plated) stranded Teflon insulated wire to equal the resistance of the stock coil.
    2. Match the inductance of the 18" coil to that of the inductance of the stock coil.
    If, in fact, the coil for this Garrett PI machine is a concentric coil, match the TX coil to the stock coil for resistance and inductance. The RX coil has a little more latitude for adding an extra few turns to improve the sensitivity.
    Measure the stock coil and post your results.
    bbsailor
      What's the advantage of the tin plated vs the silver plated wire?
        Silver plated stranded wire is too conductive and does not break up the eddy currents that would be detected at at low delays. Tin plated stranded wire does break up the eddy currents into the individual strands which will allow for a slightly faster sampling.
        bbsailor
          Hi BB, ok the connector on the monocoil 8" is a 4 pin. I measured 77.8 ohms and 470 uH and 4.1 ohms at 285 uH. You are right BB about 2 coils, it has a transmit coil and a receive coil, after looking at a monocoil on the Garrett website they show this. Ok BB I will let you look this over. Thanks for the help. Oh I have an 18" spoked round coil housing from Hays. Back to you.
          John Tomlinson,CET
            Mono Coil Infinium
            HELLO WIRECHIEF
            THE MONO COILS OF INFINIUM WORK WITH A INTERNS CIRCUIT .THEY ARE DIFFERENT FROM THE COMMON MONO COILS.
            THEY POSSESS A RX AND TX AND THAT CIRCUIT SIMULATES A MONO COIL.
            NORMAL MONO COILS DON'T WORK IN THE INFINIUM.
            I WILL SEND YOU A SCHEMATIC OF CIRCUIT FOR YOU.
            B EST REGARDS
            BEN-HUR RIBAS
            HUNTER TECHNOLOGY
            METAL DETECTORS AND COILS
              Hi benhur, thank you very much and yes I would like to try and make a larger coil for my Infinium. I appreciate it and happy hunting!
              John Tomlinson,CET
              John's Detectors
                John Tomlinson,CET
                John,
                The 77.8 ohms at 470uH looks a little odd for just coil wire measurements. I suspect there may be some active or resistive components in the coil housing. If you get any additional information please post it or email it to me so I can better analyze the circuit.
                bbsailor
                  Hi BB, yes just what I thought. I called Garrett and of course I was told that the coil technology they use is proprietary. I will keep looking and thank you much BB.
                  John Tomlinson,CET
                    Hello, wirechief the schematic of internal circuit of monocoil infinium is in your privat e-mail.
                    best regards
                    Ben-hur Ribas
                    Hunter Technology
                      Infinium mono coil
                      Hi BB
                      best regards
                      Ben-hur Ribas
                      Hunter Technology
                        Internal circuit of monocoil infinium Ls
                        Yep..would like the schematic of internal circuit of monocoil infinium Ls also
                        best regards
                        PiQuest
                          Internal circuit of standard DD infinium Ls
                          Hey.. Hi
                          Wondering if the standard DD infinium Ls uses a internal circuit, similar to the mono's.
                          *Any one know what pins go to ground on the Infinium Ls 4..pin plug.
                          Great Forum... "Happy New Year"
                            benhur,
                            I would be interested in the schematic as well. I was also told that the Sea Hunter MkII has electronics in the coil also. Didn't know if it was the same, or if you have that one as well.
                            Has anyone ever found a source (other than Garrett) for the 4 pin connectors for the Infinium and Sea Hunter?
                            Thanks,
                            Robert
                              Hi Benhur Ditto on the circuit for the infinium mono coil. I have often wanted to make one for mine... Send to [email protected]
                              Thanks...
                              regards Ismael
