Hi Folks,
I know several of you good people have tried a variety of shilding techniques and materials. I have tried aluminum foil (kitchen variety), self adhesive aluminum and copper tape, Which is I am told too thick. I have seen the carbon based sprays and have used it for static disipation in the past. I hear about the nickel based paint, but have never seen a source for it. What about Aluminum paint? Has anyone actually tried it? I was planning on spraying a little test strip and seeing if it is conductive. From previous posts I gather that too heavy of a shield can generate it's own eddy currents masking the desired ones. Anybody have any idea what the actual resistivity should be? How do you actually measure it? Is there a standard size or shape? The entire subject of shielding materials seems very difficult to quantify. The folks who make detectors have somehow managed to come up with materials and methods which give them desirable consistant results. I personally have only seen the inside of one commercially produced coil, (Older Whites 4B)and it has no apparent shielding at all. Any responses will be greatly appreciated.
Russ_NY
Russ_NY
