coil inductance calculating
  • coil inductance calculating
    Do anybody know link or have a program of coil calculating?, i would like to make square 40x40 cm coil for PI detector
    Re: coil inductance calculating
    Click "search messages" and type in "coil formula" - it's already been posted before by Claude. Hope this helps. I have Gary's pi and I'm building the 1m x 1m coil as we speak. Stay in touch with your project. Maybe we can compare notes.
      If you go to the Java Script Calculators on my site, you should be able to calculate the square coils fairly Accurate.
      For a Square coil, First Figure out the Aproximate Equivalent it would be if it were re-shaped as a Round coil.
      Look at the Calculators
        thank you for help, you have great site and your PI projects are perfectly described, keep going so !
          www.qsl.net/yo5ofh/doc/calculating%20coils%20for%20hf.htm
