12" Coil For Whites XLT/Quantum/Etc?
  • 12" Coil For Whites XLT/Quantum/Etc?
    I haven't searched this forum yet but has anybody made a 12" coil for the XLT, Quantum, etc? I have a QXT Pro and would like to max out coil size for most depth on coins. The only commercial coil for them that I know of is the Hot Shot. I tried two but they became unstable on my QXT Pro for some reason. Either it's my machine or they don't like QXTs. Not sure.
    I've owned many machines over the years and gone "head to head" with others on undug targets. Up until now the only machine I'ved used that beat the QXT depth wise on copper and silver targets was the Explorer but only in mineralized soil. In normal soil the QXT got me as much depth, but I set the QXT for max depth (no discrimination, no noise reduction, sensitivity at 18, listen for the high tones, etc). Combined with the fact that the QXT is lighter and less taxing mentaly to use (less ID and audio float on deep targets without work), is much faster at target seperation, etc.
    Recently a friend bought an ETrac and we did some more testing before digging on targets. For the first time in unmineralized soil the QXT could not easily get an ID and high tone on two targets, both of which turned out to be silver dimes, while his ETrac sounded loud and clear on them with a solid visual ID. Now, since I run the QXT "all out" I'm not convinced that the newer electronics he's using is getting him the extra depth. I feel it's more due to the 2" size advantage he had in coil size of his 11.5" versus the 9.5" stock QXT coil.
    So, I'd like to build a 12" or so coil and compare. If he's still got an edge on depth I'll spring for the ETrac (or XTera...which we'll be testing as well), but I'd at least like to max the QXT out first and see how it does.
    I do have a background in electronics so with the right information on the coil specs, measurements, etc, I can build one. I also have some experience winding brushless motors which is sort'a similar in principal. Just need to find out who's done what with Whites coils in the 12" range.
    OK, here's what I have so far. 9.5" coil for XLT, QXT, Classics, etc. TX L=540uH, R=1.4 ohms. RX L=36mh, R=122.8 ohms.
    From what I've read thus far it's critical to wind your new coil, regardless of size, to match the 540uH. The resistance value should also be as close to the 1.4 ohms as possible but isn't as critical, so something ranging in the 1 to 2 ohms range for the TX would probably be fine.
    Now, the next critical question I have is how many winds are being used and what gauge of wire is in the 9.5" coil. I have not been able to find this information on the web. I'm wondering if somebody has a general idea of what gauge wire should work. I would figure that it isn't very important, in that you just wind the wire until you reach the proper numbers above?
    Then comes construction. Where do I get the coil plugs? Are they CB microphone plugs or can they be found at Radio Shack. I'd prefer not to have to order them. What about the shielding material and so on? I'd rather use cheaper and/or more available parts without having to order them online but will if I have to.
    I'm slowly digging through the old messages in this forum so some of these questions are probably answered. If I find anything of interest I'll add it, but I'm hoping somebody can chime in here.
