1) If a transmit coil was wound with the individual loops in parallel instead
of series, would this result in a faster rise and decay of the transmit
pulse? What effect would this have on the EMF?
2) if a transmit coil was wound with two wires wound in opposite
directions, interlaced, with inputs and outputs siamesed, would this
have the same effect as a bucking coil on a concentric or Tx+/Tx-
coils on a coaxial? Or would this kill the field?
3) Is a bucking coil necessary for a concentric PI design?
4) Two coils are wound, both with the same length and dia of wire. 2nd
coil is smaller dia with more turns. What differences exist in the
inductance/capacitance/resistance characteristics between the two
coils?
5) A wirewound coil, with it's roughly circular cross section,has a certain
shape to the EMF. Tesoro's Sandshark uses a spiral wound printed
coil, which has gotta have a different shape for the generated field.
How do the two designs react to ground effect? Are there any other
advatages/disadvantages between the two designs?
6) Bbsailor calls for 19 turns of #30 for his coil design for the
hammerhead. If the same coil was wound with fewer turns of a larger
dia wire, wouldn't this result in a quicker rise and decay of the xmt
pulse, due to lower resistance? How would this affect the capacitance
and induction characteristics?
7) I'm new at this stuff, so I saved this one for last. Is there really such
a thing as an induction meter???
coils?
