I got my White's TDI a couple of weeks ago and had started to get desperate and was even thinking of selling it because of its lack of usable discrimination (I don't think that I will ever get used to the kind of discrimination it is supposed to have, as explained on some sites - by switching to high conductor and offsetting the GB). Plus, here in Bulgaria most coins are low conductor coins and if I switch to high conductor only, I'll lose the ability to detect them, not to say that when you offset the GB, the depth decreases also. But yesterday I went out to hunt for coins with a buddy who has a ML GPX-4500 and he was laughing at me how useless the TDI discrimination was and said that I should have bought a GPX instead. I was using the standard 12" concentric coil. At some point we decided to try the GPX 11" DD Commander coil on the TDI, and what a difference - with the target conductivity switch set to ALL the detector produced wavy (changing pitch) sound on every ferrous target we tried it with - various iron coins, small and medium sized nails and some others. And the signals from the non-ferrous objects were clear and stable and the pitch was not changing on them. The sensitivity to very small iron objects was reduced also, which should be a good thing for coin hunting. The detector wouldn't detect them. We didn't bury the test targets. Just put them on the ground and tried sweeping the the coil at different heights over them, so I believe it should be the same as if they were buried. I am going to get a DD coil for my TDI now.
Have anyone else tried using a DD coil on the TDI and what results did you get?
