Whites 15" coil info
  • Whites 15" coil info
    Can anyone tell me which pins on the Whites 15" round coil are for transmit- recieve & shield.
    pin 1 RX-
    pin 2 RX+
    pin 3 Shield
    pin 4 TX+
    pin 5 TX-
      Thanks Carl
      New someone on here would know. Mark
        White's TDI 5 pin connector with standard 12 inch coil
        I would like to do a continuity test to determine if any breaks or damage exists in the search coil assembly. My understanding is that it is a dual field coil;therefore:
        Should pin 1 only show continuity to pin 2?
        Should pin 4 only show continuity to pin 5?
        Thanks, Mike.
          Yes, although in some loops the RX & TX coils might share a ground. I think on the 15" loop the RX- is internally connected to shield, so pins 1 & 3 will appear shorted. But I think the TX coil is isolated.
