The Jimmy Loop is a Mono Search Coil with a White's Dual Field design. Yeah, I know, just what does that mean?
According to Jimmy Sierra, "This means that it has two distinct sets of transmit and receive coils: a large outside coil maximized for larger targets and a smaller center coil to hear those tiny pieces better."
Let's think a moment here.
TWO sets of COILS.
Without ripping into a TDI search coil it appears there is an outer mono coil and an inner mono coil each with its own set of TX and RX operating at the same time.
Brilliant!
So, it appears that the TDI is designed to run two mono coils simultaneously as a standard search coil configuration.
My thought is it would be nice to have an eliptical design and that is just what Jimmy has to offer. An important notice goes along with the Jimmy coil and the Dual Field design: "This loop is designed for use only with the PulseScan TDI".
I'm thinking that it can't be used on any other White's detector...
Yet, can it also mean you can't use it on a MineLab?
Not like anybody is crying about that. If that were true, then the TDI search coil is exculsive to the TDI only and interchanging ML coils could make the detector not function properly as designed. Now I'm over thinking here and making myself sick.
vs
I own a TDI and GP 3000.
I will never use my ML coil on the TDI because from what I understand it is a DD coil. And from what I understand about the TDI...I will only consider mono coils.
Maybe best for me to save up my nickels and get a Jimmy. Until then...
What I or we need is a schematic of some sort for this dual field thingy. Anybody got any ideas?
Brilliant!
