I live in italiy, Rome and me I have this passion for the search from more than 25 years.
I have little experience of electronics and I would like to build a coil 11 DDs for my gp extreme. In italy there are some grounds very mineralized and the gp extreme as the others of the serious sd/gp/gpx, are insuperable. But unfortunately these detectors have some problems of discrimination. I could never use a mono coil, I would become crazy!
I have a coil of the coiltek from 11DD and I have modified some things (for my small experience) and I have to say that it is all right in discrimination and established .
I have opened the coil and I have replaced the two sheets of paper that have the varnish of screening in graphite, that measures ohm 200, with some new sheets of paper with varnish of pure graphite to 95%, the graphite is in dust a lot of goal, mixed with some glue for wood in relationship 1 to 10, that is a part of glue and 10 parts of water. I have made four passages of varnish of graphite and I list you the various measurements for every passage of varnish:
First passage, measurement with the tester to 20k 18,50, measure taking on the most external part of the cardboard
according to passage, measurement with the tester to 20k 10,00, measure taking on the most external part of the cardboard
third passage, measurement with the tester to 20k 6,50, measure taking on the most external part of the cardboard
fourth passage, measurement with the tester to 20k 5,00, measure taking on the most external part of the cardboard
Perfect job! Very important thing I have prolonged the thread of the screening of the coil of 4 inches, (10 centimeters), in the inferior part of the coil, (copper thread that is to contact with the varnish of graphite).
In this way the detector has improved of very its discrimination and his established in the grounds very mineralized, the depth has remained the same one.
Other thing that I have modified is the small resistance that is connected among the two terminals of the smallest wrapping of the coil that it measures ohm 6,3/6,4.
This small resistance of the coil original measure ohm 619 and me I have replaced this resistance with one from ohm 280.
I think that this small resistance regulates the voltage of the coil and in this way it passes more current to the coil, I have to say that the detector is faster in the search, as if the detector had more gains, the depth is increased of two inches (5 centimeters).
This for me has been a great satisfaction, but unfortunately there is always some problem, when in use the detector in the grounds strongly mineralized, the detector is not stable and feels the mineralized rocks.
I ask you if you have the possibility to resolve this problem, and to understand what he is able to modify for maintaining this depth of the detector, also in the grounds strongly mineralized!!!
The measures of the two wrappings of the coil 11DD of the coiltek measure ohm 6,3/6,4 and ohm 0,9/1,0
I over this problem, would like to build a new 11DD coils, even with your experience, to be able to realize a 11DD coil that is superior of this coiltek coil!
Excuse for mine bad language English and me I hope that you what I have written you!!!
Thanks of your patience and courtesy.
Bruno.
