coil mono( p.i) question??
  • coil mono( p.i) question??
    HELLO!what is the difference between 2 -,coil,s one without insulation and other,coil, insulation?
    what is the best material to insulate before the plastic seal on the box '?
    What do you mean by insulation?
      the specific question, is it? there may be, interference, detection, if the reel,(COIL) is not isolated before the close, the plastic box?? if mesmopreciso isolate the entire wire coil, which is the best insulator (tape)? Why not is possible, for a maximum sensitivity = 11 in my deepers-7 (PI) sera, I HAVE MORE BY 0.8 OHM, the impedance the coil, OF ORIGIN?
        INSULATION=SHIELDING?
        Carlrod49, Por favor use tradutor do Google para enviar sua pergunta em Inglês, ou enviá-lo para o Português. Seu "insulation" termo significa blindagem (shielding)?
        Mike-BG
          hello my friend. Help me build the coil as you did 50x50cm (circular). Do not be evil. You already did it, Hecham hand. What should I use?. Of course, for the Deepers 8AT. Thanks.
            You need to follow the same inductance as for smaller coil in first line. Hard to imagine how 50x50cm can be cicular?
