hi every one ,now i have 2 working older Detectors after we read the way to fix the sound on my garrett A.D.S deepseeker witch i have had for many years , i all so have a Coinmaster 6/db with a small coil and a large coil witch coil would be better used on the beach ? and dose any one still use these older machines like me?
The 8in obviously is better in tight areas. I will be better on smaller targets and will see less minerals if the ground is hot. If you're using this on open beach the 14 will better at coverage. Have a rod for each for easy swap.
