After my first some what successful attempt at creating a spiral coil (I still need to experiment with shielding), I decided to do another coil. My first coil is really sensitive, but I just didn't have much luck in the depth department. I need a general purpose coil so I am now trying to build a bigger coil.
I know there are advantages to having a spiral shaped coil, such as speed (my first coil is really fast -even on the small objects!), but I decided to attempt a mono loop. Hopefully the higher capacitance won't make this coil too slow.
I first did my calculations as usual, using Gary's' Inductance calculator. I used Litz 13/30 (19 AWG) this time. Last time, using thinner litz got me a slightly high resistance (.898 Ohm Vs Target .5 Ohm). Although my coil worked, I will never really know if the slightly higher resistance has anything to do with my coil's failure to detect medium sized objects at depths greater than the 7-8 inch threshold.
The variables:
Inside Diameter: 11.5 Inches
Target Inductance: .3mH
Wire Gauge: 19 AWG
Coil Length: .25 Inches
The calculator's estimated Results:
Inductance: 0.3252 mH
Resistance: 0.5864 Ohms
Turns: 24
After finishing my winding, my final values didn't vary that much.
Obtained results (after tightening the coil with craft tape):
Inductance: .312 mH
Resistance: .520
Turns : 25
My guess is that the discrepancy lies in the fact that the litz wire isn't actual 19AWG, but a close approximate.
I used some craft gift tape (made out of non conductive material -I hope) to tighten my windings.
and voila!
I want to shape this coil into a perfect elliptical shape. Any one have any suggestions?
The variables:
Wire Gauge: 19 AWG
Turns: 24
Inductance: .312 mH
Resistance: .520
Turns : 25
and voila!
