coils for delta pulse
  • coils for delta pulse
    hi all
    please any one knows about the coils of delta pulse
    25"
    40"
    60"
    the corect data
    of how many turns, and coil caractristics
    Hello Goldin
    M gave good results:
    40x40 cm coil, 24 turns, 0.5 mm conductor diameter. Computer network cable, 8 drivers, 3 laps (8X3 = 24).
    Damping resistance of 560 ohm and 2200 ohms in parallel, 1 watt.
    Jose
      need 1 meter coil parameter
      turns?
      ohms
        For 1X1 mtrs coil, delta pulse.
        17 turns, 1.5 mm conductor diameter.
        Resistance of about 2 ohms
        Damping resistance, experiment with approximately 400 ohms. 1 watts.
        Jose
          thanks
          thanks
          but i have question
          i have wire 1m with thin insulation
          should use thicker insulations
            I think it would have no problem with these values of conductor (1 mm)
            Reduced isolation could affect the time delay, but not serious drawback in this type of coil which in itself is a long time.
            Jose
              thanks
              thanks jose for replay
              just my last questions
              should i use 100 hz for large coil
              because i already use 400 hz for 25 cm coil
              i make large coil 1m it detect coca cola can about 1.4 meter
              is that good
              i try 16 turns and 11 turns no difference
              ohms 2.5 ohms
                100Hz to 200Hz is good for coil 1 X 1 m.
                In my case it worked fine 17 laps, 160 Hz
                11 laps is little for the Delta Pulse.
                It is a matter of testing and comparing results.
                Jose
                  thanks
                  i understand
                  thanks jose
                    is that good
                    you have to URGENTLY turn on your imagination. another way you will only ask all time. for big coil the cola can is like small coin for 10" coil. is it clear for you or not? Delta Pulse is DEEPER, it is NOT working on short MAIN SAMPLE DELAY and bad sens for cola can is NORMA. MAIN SAMPLE DELAY minimum is only 40 μsec in DP. if you want to INCREASE the sens you have to DECREASE MAINS SAMPLE DELAY to 10...12... μsec. is it again clear for you?
                      yes
                      it is clear
                      i already know that delta pulse dosent work in low delay
                      and i know the second delay havent effect in detection depth but in stability
                      i only need to know what depth it is normal detection for coca cola
                      in small coil 23 cm : i get 85 cm
                      in large coil :1.4 m
                      is that the maximum ?
                        These results are very good!
                        Jose
                          Coils 45X45 for DP
                          Coils 45 X 45 for DP
                          Scotch tape shield No. 24
                          UTP cable for computer networks (4 pairs, 8 conductors), 8X3 ... 24 laps
                          Jose
                            What is recommended inductance for small coils (20-30cm diameter) for Delta Pulse?
                              I don't recommend small coils for this thing (only for testing in home).
                              Detecting with such coil on the field is going to be disappointing (means useless).
                              Otherwise it's 350uH to 450uH.
