Redheat mk IV lightning coil
  • Redheat mk IV lightning coil
    Hi lads ive had trouble with my coil ,the connector was loose at the coil end and i was doing some air tests and turned it slightly and it started giving better results so ive opened up coil ,but i dont really know what im doing ,its a four pin coil concentric wide scan ive done a continuity test to see what wires go to the shield,only three go to the shield should all four go to the shield and what does the shield do as its only melted into bottom part of the coil,should the paint on the bottom lid be conductive or not,please help as im trying to fix it now,i can send pics if it helps
