I came across this discussion:
http://www.daycounter.com/Calculator...lculator.phtml
In our use of the coil as a TX coil head, do we consider the coil as having a variable core material - air when above ground and ground mineralization content when close to the ground? Thus placing the coil near the ground affects its inductance?
Has anyone done tests where you drive the coil with a squarewave signal and look at the current waveform with a scope to determine the saturation point? I wonder if this would be a tool for us to optimize the TX coil design and pulse timing parameters for our given coil and also perhaps explain issues some people are having with MOSFETs getting hot in their tests (coil inductance too low).
Barry
Barry
