Measured inductance on DIY surf PI coil
  • Measured inductance on DIY surf PI coil
    Hi all
    been trying to go through my old notes
    been trying to find the measured inductance of DIY
    coil for ORIGINAL surf PI, I know its in one of the threads but cannot locate the right thread
    The specs for the DIY coil seem to be 20 turns, 9 inch or 23cm dia, .5mm wire or #24 awg
    any body made a coil to those specs and measured the inductance ?
    was it around 230uH ???
    thanks 6666
    try this
    http://deepfriedneon.com/tesla_frame6.html
    use point instead of comma
    the coil should have 300 microHenry +/- 50
    my coil a made of 0,5 or 0,6 mm lackered copper wire 23cm diameter in range of 18-24 turns - works all
    donĀ“t hit me if i say to much wrong
      Thanks for the link
      I wound up a coil today, 20 turns, 9 inch or 23cm dia, .5mm wire or #24 awg
      and tried it on my brand new LCR meter
      and it measures 230uH on the meter
      Has anybody else done a real life measurement on this coil for surf pi
      I have worked out how to use this and will try making one
        See my "Surfmaster PI Pro coax bad" thread. I measured the real-deal surf pi and the pi pro. I know the pi coil is good. The pro coil was water damaged but seemed to measure inductance within reason - I think it just has too high capacitance. Hope to find out this weekend.
          yes every coil a made i measure with lcr meter too. it is close to that what the coil calculator says i linked.
          keep in mind the accuracy of meter changes some percent depending to measure range look in manual of your meter. in this low range my has a accuracy of +/- 5 till 10%
          can i help you
