Is there an inductance formula for DD coil, is there a "Wheeler" equivalent?
  • Is there an inductance formula for DD coil, is there a "Wheeler" equivalent?
    I'm building my first E-trac coil. I took some measurements of the Minelab stock coil with my RLC meter. Here is what I got when measuring the coil's output pins 1 thru 5:
    1. pins 1 & 2 Resistance = 1.1ohm, Inductance = .54mh
    2. Pins 3 & 4 Resistance = 5.8ohm, Inductance .69mH
    3. Pin 5 Resistance = open with all other pins (drain pin)
    I'm using Barry's Inductor Simulation to determine what guage of Magnet wire to use.
    http://www.coilgun.info/mark2/inductorsim.htm
    However I want to build a D-coil. How to componsate for the change in geometer from a perfect circular shaped inductor to a D shape coil? Is the a Wheeler's equilavent formula to model the following parameters (X,Y,Z) as shown in the attachment?
    Thanks,
    Majesus
    I once asked the same question. The answer I got was something to the effect, measure the overall length of wire in one winding of one D section and substitute that number for circumference in the formula:
    diameter = circumference/pi.
    Then, plug diameter into your favorite coil calculator. (Why didn't I think of that??)
    It might be simplified but you will be in the ballpark. Somebody with more time and motivation than I could maybe work out a useful 'k' factor to apply to the result.
      Simple enough.
      I can model the coil in Autocad to see how I like the inner geometer and then determine the circumference from it.
      Then use the following calc to get my AWG and outer dimensions.
      http://www.circuits.dk/calculator_mu...er_aircore.htm
      Gives me a starting point.
        I did some experiments along these lines last year. I made a circular coil, measured its inductance, and then re-shaped it to a rectangle, with approx 2:1 aspect ratio. The coil L was remeasured.
        Details were: 100 turns of 0.25mm diam ECW.
        Circular coil, diameter 48mm: L =980 microhenry.
        Reshaped coil, 55mm x 28mm: L = 880 microhenry.
        Note: the rectangle shape has rounded corners, bend radius approx 6mm.
        So L is reduced by 10 percent in this case. I think the reduction for a D coil will be less, probably 5 to 8 percent.
        Hope this helps.
          I've just thought some more about this, and have worked out the theoretical size of a D coil made from my example coil (above). It's actually very similar to my rectangular coil, so maybe an L reduction of about 10 percent is a fair approximation when going from a circular to D shape with the same circumference.
          Maybe you could wind a crude test coil with less turns, for example, on your former, then measure its L and use this data to guide your final coil design.
            Now that I can ball park the AWG I need, I was going to wind it, strip just a little of the insulation to measure while on the JIG. If I need more turns, revarnish the nick and keep winding.
            5 to 10% from a circular coil to a 2:1 D coil. Hmmm, I'll take some measurements once I CAD the geometery and compute the diameter as per porkluvr's suggestion and calc the inductance using an inductor calc.
            See if the inductance is 5 to 10% different.
              Re: Minelab stock coil
              Majesus, do you have a signal generator and oscilloscope to measure the resonant frequencies of windings in your Minelab stock coil? What is the overall diameter and weight of Minelab coil?
                The other thing you could do, of course, is when you wind your coil, bring out a couple of taps near the end. This will allow you to fine-tune after winding and varnishing,etc. Example wind with 40+2+2, this allows 'ideal' +/- 10%. If you isolated the extra winds, you could join them back in reverse, ie. winding 40 & 2+2 would allow 36,38,40,42,44 T coil. Hope this helps.
