Originally posted by kt315
View Post
The design of each windings in the search head should observe its efficiency at given weight limit of metal.
The efficiency of TX winding has dimension ampere turns per kilogram wire. This function increases with capacitance of TX tank. We should use large TX capacitance and reduce turn number in order to operate with high ampere-turns. High efficiency of TX means both low weight of battery and low weight of search head.
The efficiency of RX winding has dimension S/N per kilogram wire. Unfortunately the sensitivity of conventional metal detectors is not limited by thermal noise. Despite this, it is better the preamp to operate with more large TGT signal in input. That means maximal turns number of RX winding which is limited by resonance frequency. To increase turns number, we should use minimal capacitance for RX tank. Note that in above design there is a resistor 51 ohm, which increases both the thermal noise in input and the weight of RX winding. The noise increasing is not significant, but we can reduce the weight of RX winding if instead resistor 51 ohm, we use wire with more small diameter.
