Coil without coil!
  • Coil without coil!
    For handheldable deep-search every coil that is over 50cm/1.5ft diameter starts to get very heavy and "unusable".
    And the 2box method also is not the best solution - because one coil should be left and one should be right while walking and not: before-behind.
    The pics here:
    http://www.pulsediscriminator.net/gallery.html
    show a much better and lightweight solution.
    Can we use those kind of antennas for depth metal detection?
    The pics here:
    Maybe. But just in case, bring two and a plank so you can have a picnic table.
    Sorry...
    -SB
      Why is that?
      Only if your metal detector is GPR, not induction.
        Useful readings:
        J. Hettinger, “Aerial Conductor for Wireless Signaling and Other Purposes,” Patent
        number 1,309,031, July 8, 1919.
        Acoustically Driven Plasma Antenna, Patent number 6,087,992, July 11, 2000, T. R.
        Anderson
        Plasma Antenna With Electro-optical Modulator, Patent number 6,087,993, July 11,
        2000, T. R. Anderson, et al
        Horizontal Plasma Antenna Using Plasma Drift Currents, Patent number 6,118,407,
        September 12, 2000, T. R. Anderson
        Reconfigurable Plasma Antenna, Patent number 6,369,763, April 9, 2002, E. G. Norris, et al
        Expandable Antenna, Patent number 6,512,496, January 28, 2003, Igor Alexeff, et al
        Establishing Highly Conductive Path in Gas by Thermal Guidance of Discharge, Patent
        number 3,775,638, November 27, 1973, D. Tidman
          Hi all,
          we are dealing with hundreds of MHz or even GHz.
          Penetration depth suffers so much. The skin effect of the ground dominates here.
          GPR's have their own legitimacy. But the inductive operating metal detectors get more.
