D coil shape
  • D coil shape
    All, made a Tx coil - now its off the template - its not a D shape.
    The straight portion of the D has a curve. Is the OK ????
    Or
    Does the D have to have a STRAIGHT part - is a curve ok....
    Part of the reason I ask is - if I leave it alone its 5.996mH - off the bat.
    http://i944.photobucket.com/albums/ad289/Steve-ola/SP_A0138.jpg
    If I get the straight bit straight it L goes down to about 5.7nH - and I cant add more turns easily....
    Steve
    Or
    Steve
    No, it hasn't to be straight, even better if it is a bit "oval".
      curve is ok
      maybe it is easier to null
      you only can have problems to get coil enclosure the most have a straight middle part
      but i can be that your coil fits in there too
      i dont know how big your curve is
        curve is ok
        Yes, coil enclosure sometimes can be limiting factor, i also experienced that once.
          the post before was overcrossing with ivconics
          a the moment i tip the letters on my keyboard he gives you already the answer
            Thanks for the replys guys. I really do want to make a practical unit. I will post to completion.
            Tx coil I spoke of...
            http://i944.photobucket.com/albums/a...a/DSCN1311.jpg
            I made it with 30SWG (0.315mm copper) 115 turns 5.99mH
            210mm wide dimension
            I will freeze the shape with polyureathane resin
            Steve
              Coil direction
              I know you all know this. I have read about it but hey Im still not sonvinced I get it.
              The TGSL coils write up says wind both the same - a D coil - clockwise. say Tx.
              I did another for Rx Clockwise again - start and stop in same place as the first one.
              Now this is my confusion Lay Tx coil down on table... ok... get Rx coil and lay opposite Tx coil with small overlap as instructions -- What is not said is.
              1) do you flip Rx coil on vertical axis ????? So turns go Anti clockwise
              2) do you have only mirror image of Tx coil - no flip or what?
              http://i944.photobucket.com/albums/a...a/IMG_0002.jpg
              lost as ever
              Steve
                lost as ever
                Steve
                Hi Steve ,
                I know it is confusing , but as far as I know it does not matter as long you get a single beep when a target passes the coil at a normal height.
                With a double beep you should reverse the Rx leads ....
                http://www.geotech1.com/forums/showp...postcount=4411
                kind regards ,
                Dennis the Mennis
                  5.7mh
                  Theres nothing wrong with 5.7mh so make it the D shape you wanted infact thats Tesro manufacured spec for the TX coil, just make sure your RX is 6.2mh
