My father-in-law has just purchaced a T2 special edition and has a broken coil ie when the sens is turned up it gets a lot of feedback(iratic chatter) can this be solved by cutting the plug off and resoldering the wires back on. It aint the machine coz its been tested with a 4" sniper coil.can it be a bad conection?
teknetics T2 coil problem
Originally posted by maddogchilli View PostMy father-in-law has just purchaced a T2 special edition and has a broken coil ie when the sens is turned up it gets a lot of feedback(iratic chatter) can this be solved by cutting the plug off and resoldering the wires back on. It aint the machine coz its been tested with a 4" sniper coil.can it be a bad conection?
T2's (and F75's) are chattery when 'wound up' fully, and do pick up electrical interference. They are quieter with the 5 inch coil simply because it has a smaller size recieve coil.Try it somewhere you believe to be 'electromagnetically quiet', eg. a rural area. Be aware the discrimination setting has a very significant effect on sensitivity - disc settings around 20-25 give the lowest sensitivity.
