Dual Field on SURF PI
  • Dual Field on SURF PI
    All I want to make a dual field coil for the Surf Pi - (silverdog long board)
    Anyone done a good one already.
    Looking for 30cm air test on UK £1 coin
    Steve
    bump
      Hiya!!!! Somebody has done this, I KNOW I read it on here, somewhere,.. but blessed if I can find the thread, now!!!!!!!
      They broke the connection from R7, with the junction of R6 (the damping resistor, )and coil, and placed the second winding in the 'gap' (from end of R7, to joint of R6/main coil),
      if I remember correctly,... seemed to work OK, but cant recall any more details,... anyone else remember the thread?????
      Cheers, Fred
        The simple KISS explanation of dual field coil is basicly this
        say you have a 10 inch 300uH coil
        you need to split it into two windings
        the 1st being 150uH 10 inch winding
        the second being 150uH 5 inch winding
        wired in series, same direction
        you will probably get other reply's
          field increasing effect is better if the inner coil has near 2/3 of diameter than outer coil
          (coil coupling effect)
          outer coil 30cm
          inner coil 20cm till 23cm or in that area
          looking for user aziz and his analyzing of different type of coil
            Dual Field Pi Coils http://www.geotech1.com/forums/showt...ght=Dual+Field
              Sure thx guys, hadnt realised it was 2 Tx coils in series.
              Steve
                Cheers, Fred
                Hi Fred, I think this was the post you were referring too: http://www.geotech1.com/forums/showt...wer#post127934
                Its not a Dual field, it was for separate RX & TX coils
