Hello, I am new here, and am having trouble building a "simple" coil. I have asked here and there and have read pages upon pages but still basics seem to elude me.
The task is to build a step-up transformer from +/-4 Volts to +/- 50 Volts at 200 KHz and a secondary load of 500 Ohm to 2K Ohm (rough average 1K Ohm).
I have built 4 transformers with two types of ferrite cores and various results : they all have bad regulation, as much as 66% and it seems the greater the step-up the greater the regulation.
I have used RM10 and RM12 formers with N97 which seems to be the right material at 200 KHz having u=2300.
My knowledge is small. I know what currents will be used on the primary and the secondary, and the impedance seen on the primary when the secondary is 1Kohm with a 1:12.5 turns ratio.
So I typically wind 2.5 to 10 turns on the primary, and then wind 25 to 150 turns on the secondary (this bit is very laborious, and I usually lose count). I then plug the transformer in and observe its regulation, which is usually very poor.
I would appreciate any help to be able to calculate how many primary turns I need to be able to minimise regulation, so that I can get 50V on full load without jumping to 70V on no load.
