white’s
  • white’s
ID:	423097 Click image for larger version
ID:	423096 Had a friend pick up one of these for $8. He says the battery won’t charge. He checked and a new battery cost $60. Any way to fix to accept AA like the V3i or TDI? Just thinking odd battery voltage
    because USA is not so poor county price expensive. throw out Ni-Cad sells (4 pcs) from bat enclosure. set Li-Po.
      The same battery housing was also sold for standard C cells.
        The guy doesn't know if the unit even works. Thought I'd run jumpers to the internal power connections and apply 6 volt DC and see if it powers up before trying to make him a battery pack.
          is this QXT or what?
            Looks like an Eagle Spectrum.
              Yes you’re right, Eagle
                look at post #7 on the link
                https://www.geotech1.com/forums/foru...thium-batterys
                i used 2 lots of 4 AA batteries,(same volts more current) making the same size of housing by rewiring an 8 and a 6 battery holders
                  I made leads from the case and used a 6v lead-acid battery​.
