There is only one detector better than Deus - it is Deus with larger coil!
From the beginning, I suspected in some fishy hoax by XP. The ORX has dots on the board that are provided for connecting another mini USB connector for update. But that is not documented anywhere. With a little effort, they are easy to locate and an additional USB connector can be connected, through which an update can be done. The moment it connects to the pc computer; the remote automatically switches to update mode. And to great surprise and astonishment; update for Deus 2 goes quite smoothly on ORX !!?!? Unfortunately, a similar attempt with Deus 1 fails. This is great and very good news for all ORX owners!
I couldn?t find any info on that links about. Can you please post the exact link? Thanks
Do you say multifrequency works on orx? With HF coil?
The latest news is that XP reacted very quickly and took legal action against those forums and posts on the subject. So it's no wonder you can't find anything. But we in Owoshuma took measures in time to preserve the published material. So in the coming period, we will find ways to present it to the public. So much for now.
Damn!
I must buy action cam. It doesn't go on like this anymore. Not only do I risk being crushed; I don't even have control over the recording ... BTW in the last two days I have already fallen 3 times with a motorcycle! But I learned to fall, so it passed without consequences ... Except for a few scratches and scars ...
As for the bigger coil for Deus, then Deus would no longer look like Deus, so they never made a bigger coil.
Agree. Deus is great for iron infested sites (Settlements). 9? coil is the best there. Didn?t tried yet hf coil but i think higher frequency perform better (from my experience). Reactivity 4-5 tx power 1 18khz, narrow search field, fast separation, punches through the iron. Good for hammered coins. Otherwise 11? perform good for all around.
I think i told this before, on some of the previous pages.
I am impressed with round HF coil.
I have old medieval settlement here close to my home.
A sharp hill and once in the past there was a fortress on the top of it.
Very mineralized soil. Lot of bushes, stones, rocks.
One day i took stock 22.5cm black coil with me and also HF 22.5cm white coil too.
And made comparisons.
While stock coil tends to chatter all over the place, no matter how i make adjustments; white coil remained silent all the time, with the same adjustments.
Depths the same, tough to be sure, subjective impression is that white coil is somewhat deeper.
On such places is close to impossible to move and work with larger coils.
