There is only one detector better than Deus - it is Deus with larger coil!
  • • Reactivity 2.5, this new reactivity level is fast and deep, offering a good compromise especially when
    searching new terrain.
    • Program No10 GOLD FIELD : Improved Audio Response and reactivity.
    Goldfield will give excellent results especially when combined with the new HF coils…Now difficult
    targets can easily be detected in mineralized ground. The Tone menu has been removed.
    • Lower discrimination range : For those who want more control over ferrous targets.
    Negative discrimination of 0 to -6.4 makes it possible to locate previously rejected ferrous items, the
    lower discrimination range can also enhance the signature from deep targets which may have in the
    past been ignored. These new options also offer a big advantage when searching for specific targets
    such as ceramics or even meteorites.
    • Ground Effects: Improved Tracking.
    • Improved display and signal processing compatible with the new HF 21 frequencies. The display now
    has the ability to handle detection frequencies up to 81kHz (18kHz before), now with 7 frequency
    offsets (compared to 3 previously).
    • DEUS is now compatible with a smartphone: Target information and other data can be sent by radio
    link to a smartphone. An app will soon be available to unlock these features.
    • New program No9 "HOT" : "Pro setting" this is a find everything program, based on the Full Tone audio
    mode with a very low discrimination. Hot is a very interactive program offering excellent feedback and
    target information.
    • New program No6 "DEEP": "Pro setting" for locating deep targets, with moderate discrimination and
    specific signal processing.
    • Improved Non motion / static mode: Non motion modes are now more advanced offering better
    overall performance, with an improved sensitivity to small targets.
    • New processing : Dual processing power improves navigation and a range of other parameters.
    remote and headset battery life has slightly decreased to 18 and 20 hours respectively.
    • Normalization display is now a menu feature on the WS4 and WS5 headphones.
    • The headset volume is now stored when switched off.
    • The coil name in the coil menu have gone, the serial number is now used as the coil reference.
    • Erasing a coil from the list is done by replacing all characters with 0.
    • Audio tone can now be raised up to 993 hertz
    • Target Normalization mode is on by default (Normalization is not active with HF coils)
    • When turning OFF the remote control to use only the wireless headphone, the coil restart
    • it doesn't says nothing about improving big iron and deep rusty targets sounds you know what i'm saying )
      and the pic from earlier post:
        [ATTACH]39164[/ATTACH]
        You are reading my thoughts!
        I think i founded something interesting which must be checked outdoor:
        • Finally i can trim Deus to imitate IGSL !
            nice high tone
            interesting video. omg, was not enough all the features of deus, now we have more! )))
            • Today i went out and visited the same site from the other day, same where i discovered gold coin.
              I deliberately wanted to go there and compare behavior of V3.2 with V4 and it's new features.
              I made 2 programs explained on Youtube video from my previous posts.
              I named them "Iron3T" (3 tone) and "Iron4T" (4 tone).
              But unlike on video i lowered frequency to 12kHz on both, also adjusted Silencer on "2".
              So when i first walked inside the site it was "baddabooom ... brooom ... brooom..." all over the place!
              Constantly on each step! Deus... the machine gun!
              Ok. 5 minutes later i adjusted Disc from previously -6.4 to -4.7 and all of the sudden it became much calmer.
              Because at -4.7 there is no more ceramics.
              That site is pretty much exhausted, no more finds... UNTIL i got very strong and "fat" audio with side-chatters and VDI = 99 !!!
              "A large iron" you may think, so was i. Deus was on "Iron3T".
              Than i switched it on "Iron4T" and "fat" audio changed to "brooom ... brooom... blurrrp..."! Ha!
              Logically, because guy from video designated VDI99 with 120 pitch.
              Than i switched it back again on "Iron3T" and i started "shoveling" around.
              You may not believe... but approximately between 35cm and 40cm deep; i discovered probably the nicest and largest coin in last 4-5 years!
              I took a photo of it along with the same kind of coin that i discovered the other day; just to illustrate the sizes and differences:
              • It is a coin that large; you can kill a horse with it, if you throw it!
                V4 update and features... what to say?
                Alright!
                It is too early to say anything more... but i think there is a visible improvements and progress.
                Most significant for me is obviously the ability to lower Disc bellow zero. I like it!
                I also tried XY "oscilloscope" kind of display. Interesting.
                But i don't find it very useful. It is not giving me any additional info that i already don't have with VDI and audio.
                But i will wait and test it further, until i get my final conclusion about that feature.
                Will i keep V4 update?
                Yes i will.
                It is improvement.
                P.S.
                Was it because of the V4 update or it was just coincidental; but battery at coil drained faster than usual.
                Usually i get still "full battery" indicator after such day like today outdoor. On both; remote and coil.
                But today i am getting "full battery" on remote and "one line less than full" on coil.
                Maybe because all the time TX power was set at "3" (maximum power).
                  huge coin!
                  i usually hunt with 12khz, but i saw that with 18khz you can find more small and thin coins. silencer 2 for?
                  i remember once i found a very deep silver ring, a big ring and i had same vdi 99, and after taking few shovels of dirt out the vdi was lowered.
                  I don't know why he made 120kz on 99, they don't dig 99? for me if the audio tone is good i dig everything
                  tx3 require give more power to the coil, is says in the manual.
                  • Probably because of dual processing
                      huge coin!
                      "...silencer 2 for?..."
                      To reduce small iron sounds, usually pretty small and tiny garbage on such sites.
                      Deus is calmer as Silencer is set higher.
                      Silencer at 2 provides me calmer and less erratic work on such sites.
                      Silencer at 3 and sometimes at 4 and bottle caps are gone!
                      • Originally posted by tragac View Post
                        Battery drain?
                        Yes.
                        But in this case i had today; coil battery drained faster than remote battery.
                        Which is not what i used on so far.
                        At my favorite adjustments usually Deus (remote) is signing all the time, therefore remote is draining battery faster, because of the loud and frequent audio.
                        Today too; remote was "brooom..."-ing pretty frequent and i expected it's battery to drain faster.
                        On contrary; coil battery drained faster!?
                        Would be good to know details about update essentials, but those things are usually kept as secret.
                        I listed all the new PDF's they offered on their site; but nothing that i found as explanatory towards this.
                        Could be also coincidental.
                        Usually i don't pay much of attention on battery draining because those lasts more than enough for my kind of searching.
                        • In doc which I attached ..it is mentioned why
                            "...remote and headset battery life has slightly decreased..."
                            Nothing about coil battery there.
                            • Comment
