Tektronix Oscilloscope problem
  • #31
    Fine, I hope you enjoy your scope soon.
    Possible replacement: BFR96, BFR96H, BFR96T, BFR96S, 2n5852, 2SC1803, 2SC1949
    LT4403
    Bipolar NPN UHF-Microwave Transisitor
    TRW, Inc.
    V(BR)CBO (V)=30
    I(C) Abs.(A) Collector Current=70m
    Noise Figure Max. (dB)=1.7
    @I(C) (A) (Test Condition)=10m
    @V(CE) (V) (Test Condition)=8.0
    @Freq. (Hz) (Test Condition)=500M
    Semiconductor Material=Silicon
    Status=Discontinued
    Package=Micro-X
    Military=N
    BFR96
    Type Designator: BFR96
    Material of transistor: Si
    Polarity: npn
    Maximum collector power dissipation (Pc): 500mW
    Maximum collector-base voltage (Ucb): 20V
    Maximum collector-emitter voltage (Uce): 15V
    Maximum emitter-base voltage (Ueb):
    Maximum collector current (Ic max): 150mA
    Maximum junction temperature (Tj): 175°C
    Transition frequency (ft): 5GHz
    Collector capacitance (Cc), Pf:
    Forward current transfer ratio (hFE), min/max: 30MIN
    Manufacturer of BFR96 transistor: PHILIPS
    Package of BFR96 transistor: TO51
    Application: Small Signal
    • #32
      Hi Wm6, i have only found the below transistors on some old UHF Transceiver boards, not the exact replacement, but thought to post for you to have a look and see what you think?
      Both the BFR90 and BFW92 are UHF transistors (NPN).
      Cheers
      • #33
        Forgot to mention, same package type to the original OEM.
        Cheers Sido
        • #34
          Cheers
          You can try with one of those too, check twice for correct pin connection before solder.
          BFR90
          Type Designator: BFR90
          Polarity: npn
          Maximum collector power dissipation (Pc): 180mW
          Maximum emitter-base voltage (Ueb): 2V
          Maximum collector current (Ic max): 25mA
          Maximum junction temperature (Tj): 150°C
          Transition frequency (ft): 3GHz
          Collector capacitance (Cc), Pf: 0.8
          Forward current transfer ratio (hFE), min/max: 25MIN
          Manufacturer of BFR90 transistor: PHILIPS
          Package of BFR90 transistor: TO51
          Application: Low Power, Switching
          BFW92
          Type Designator: BFW92
          Polarity: npn
          Maximum collector power dissipation (Pc): 130mW
          Maximum collector-base voltage (Ucb): 25V
          Maximum junction temperature (Tj): 125°C
          Transition frequency (ft): 700MHz
          Collector capacitance (Cc), Pf: 1
          Forward current transfer ratio (hFE), min/max: 20/150
          Manufacturer of BFW92 transistor: PHILIPS
          Package of BFW92 transistor: TO51
          Application: UHF, Low Power
          • #35
            Will do so Wm6. I have downloaded the datasheets for the two now. Will look at them tomorrow and use what seems close to the original specs if i cannot find the BFR96.
            I am sure i have the BFR96, just cannot remember where?
            Talk to you soon.
            Cheers Sido
