digipot installing - need help
  • digipot installing - need help
    hello
    for next project i want to use a digital potentiometer
    for example AD5258 or anything else
    from microchip
    maxim
    analog devices etc.
    example: i want to replace a 100k pot (maybe threshold )
    with a digipot (64 steps up down adjustable)
    can anybody explain and give tips to connect that devise instead of a ragular pot
    endresult is a foil panel with two little tactile switches for up and down
    i hope you know what i mean
    i am still at beginning at this moment- will be a new chapter for me
    many regards
    I'm sure all the major manufacturers will have excellent application notes on these parts, that are easily downloaded from their websites. The individual datasheets will also give details of any special requirements that the device has. For example, AD have pdf's, webcast tutorials, etc, here:http://www.analog.com/en/digital-to-...cts/index.html
      hello skippy
      many thanks, there is direct a pdf file with title how to change a mechanical potentiometer with a digital one or so including pictures the way i supposed how to do
      next is to order a mcp4142 and make test
      if that works my surf pi gets a frontpanel without pot knobs
      yippie
        hello skippy
        yippie
        What a brilliant idea, can be then sealed so easily to make waterproof, good one Bernte, shall be following this thread with hawk eyes.
        Then after that can use a lineup of LEDs to show detection strenth and it goes on.
          "Then after that can use a lineup of LEDs to show detection strenth and it goes on."
          also an old idea from me
          search this forum vu meter
          or this
          http://www.geotech1.com/forums/showt...highlight=3914
          hope we can improoved our detectors so
            Many of the digital pots use standard interfaces so you can program them to be controlled by a uC, or just control (any number of) them remotely on a 3 or 2 wire bus that can't act as an antenna.
              or this
              Certainly another avenue to consider, got all the original bits for the Barracuda now, hopefully will get chance to assemble over the weekend, once up and running will have a play with your idea.
                how can we get some digpots from analog devices
                find nothing here to buy them
