Nut
  • Nut
    Hello
    Does anyone known where I can buy the nut?
    your local detectorshop should have them. But it depends on your detector, see https://djlaan.nl/categorie-42-beves...aterialen.html
      Thank you very much Joop, in my country it's hard to find something like this
        Those are custom-made by each detector company. You may be able to buy replacement pieces, but they require a specific hole to be punched in the rod.
          Thanks Carl, I known what you mean, the nut will to home made rod, so no matter
            Originally posted by inio_01 View Post
            Hello
            Hi, what is the inside diameter ?
              Hello Georgi
              inside the nut should be 22.7mm
