Hi
I know this is off topic for here but still worth a shout
I got Two Hard drives here in the workshop that works for 5 minutes or so then vanishes, even though the servo keeps spinning, once turned off then back on again works for a further 5 mins, It seems to last longer when files on it via PC are left open.
After doing blind fault finding I'm pretty convinced the fault lies within the logic board on both .
What Id like to know has any of you here actually diagnosed this fault down to component level within the hard drive, or anyone got any leads on it because going through search engines advise has been freeze it, hit it, drop it etc which all relates to hard drives with servo problems, Cant find any tech info relating to actually repairing them.
It must be common because I have got two Seagate Barracudas with identical symptoms although different version numbers.
Thanks in advance
Dave
Thanks in advance
Dave
