I would avoid a hybrid CRT scope. I've had a few in the past (mostly Tektronix) and they've been problematic with glitchy digital operation. I would either suggest an all-analog CRT scope or a digital LCD scope. The Tek 465/475 were one of the best analog scopes, built to last. The later 2200/2400 series are hit-or-miss, some are good but we had a lot of 2465's go bad at Analog Devices. Kikusui generally made good analog scopes (used them in college) and had good luck with a batch of Hitachi scopes I bought at an auction.
Oscilloscope
I've been using a Rigol DS1052E. Don't know how it compares with other scopes in it's price range. Works for me. Have used analog and digital scopes at work. One advantage of a digital scope, can see the whole trace when looking at longer record times(looking at integrator noise with 500ms or 1second/division as an example). Analog scope with persistence would work also. I haven't seen a disadvantage using my digital scope playing with metal detector circuits.
Digital scopes can alias. If trace doesn't make sense, change the time base to see if trace changes.
Originally posted by Carl-NC View Post... I would either suggest an all-analog CRT scope or a digital LCD scope...
I was not in (financial) position to buy good enough digital LCD scope, so i picked and bought very good enough all-analog CRT instead.
For what you get from all-analog CRT scope; you'll need 3x ... maybe 5x more money to pay for digital LCD scope.
I have two 475A (purchased as used), both in mint state, one for work, the second for spare parts.
Purchasing suggestion:
If possible, buy used analog scope from knowledgeable person, who is able to calibrate such scopes.
Do some search and talk to sellers about their competence in field (of scope servicing).
If possible, avoid purchase valuable instruments from ignorant garage/yard sale resellers, without
prior quality check.
Old DS1052E can be even tricky "upgraded" to 100MHz.
This can be firmware upgraded to 200mhz from a 70mhz model
some come shipped already done, there is a video of an electronics person showing this, learn electronics is the name i think.
I was looking at this one as a maybe
Hantek DSO5072P, $215
Originally posted by Matt_Rowe View PostThis can be firmware upgraded to 200mhz from a 70mhz model
Rigol scopes are also known for hackability. I upgraded mine, it was quite easy.
If PC real-time analysis is important to you, check first if problem is real and solved.
Rigol are good inexpensive digital scopes and are well supported, at least in the US. DS1054z is a good 4 channel model and 50 MHz bandwidth which should be more than enough for detector work. If you can live with two channels the DS1202 is less than $300US.
Analog oscilloscopes still have advantages particularly for beginners. I am not aware of any current production models that are of good quality though. You should be able to find good used older oscilloscopes BUT you will have to know how to fix them yourself. They can be fixed and there is help but the good ones are all old. The Tektronix 465/475 were built back in the lates 1970?s that is 45-50 years old. Thinks break after that amount of time.
Originally posted by Old cart View PostI do not recommend PC based scopes. They do some things well but the update rate is usually poor and having to use a PC as a display is a pain.
d
