Where Can I Purchase Garrett Waterproof Headphone Connectors?
KT, I have been using the Buccaneers for the last several years. They work great but, the control box bulkhead fitting is rather large and will not fit the box I am using.
Have to resort to using Heyco cable glands with relief fitting.
So I am looking for something smaller than the Buccaneer so I can detach the search coil from the control box. Also, so I do not have to change the fitting on the Amphibian headphones to a Buccaneer.
reposting. did anybody use this type of plug and socket?
Hi to all Garrett Sea Hunter users for those watching that might have the VLF Series XS500 XL500 Since the coils are fixed one with a Co-Planer and the other with a Co-axial both 15khz Maybe if you are interested in changing coils since there are lots of them for the Garrett Groundhogs There is a seller in Hong Kong that has a pair of 5 Pin IP68 Rating Connectors for $10AU about $7US with free shipping (2pcs Waterproof Power Aviation Cable Connector Plug + Socket 5 Pin IP6 the link is as follows http://www.ebay.com.au/itm/301822572...%3AMEBIDX%3AIT The photo shown by me it's the Co-axial coil with the connector set up I have made with the long lead from coil witch is thick and well protected an extension lead with male and female connectors So I can use the coils with the long shaft setup or the short shaft diving setup And I will be setting up more coils from the 15Khz solid coils from Groundhogs with different sizes Good Luck
