... I took ones on LM7522 based... this is something not on this IC... STEP-UP is PROTECTING your electronics ITSELF,
because output voltage will be NOT OVER than input in case if the converter would burnt. Specifications:
Input voltage:3.5V-32V
Output voltage:5V-35V
Input current:Rated current is 2.5A,maximum 3A(Additional heatsink is required)
Load regulation:±0.5%
Voltage regulation:±0.5%
Work temperature:-40 ℃ - +125 ℃
dimension:42mm*22mm*14mm(L*W*G)
NOTE:This can't be used to step down Voltage
thanks man.
it is good choice , just i want know how current DP2 use when connect 1*1m coil and DEPTH volume in max ???
hi
it is good but when i use lithium battery (14.8 v , 2.2ampere) , the start current an not produce .so i should use 2number of 12v ,0.8ampere parallel for your circuit . if you have idea i listen .
Excuse for my English
dear KT i buy it .
if i use 2.8AH ,12volt battery ,can work by 1.1m*1.1m coil 8 or 10hour ?
