Vintage Garrett metal detector pot replacement
  • Vintage Garrett metal detector pot replacement
    I need to replace 2 pots on an old Garrett groundhog detector. The originals have no values marked on it and the tracks (carbon ) in both are badly worn so cannot measure the resistance. The only markings are numbers, probably manufacturers marks......same on both
    -1377702 93013
    Does anyone know what the values could be, thanks
    David
    What detector is it. They had more then a few going by GroundHog.
      On many pots, you can pull the metal cover off and get access to the carbon track.
      The wiper usually doesn't completely cover the carbon track and there will still be a continuous arc to measure.
      Length of arc is resistance while width of track is power handling capacity.
      eric
        Thank you for the replies.
        The MD is a Garratt Coin hunter
        Hi Eric,
        Both pots have been taken apart, both tracks have areas which are completely wiped. Perhaps a previous owner had over cleaned or even sanded the carbon track ( I' ve only just bought it).
        Would measurement of the length and width give me the Ohm value I need ?
        Thanks for your help
        David
          Look for numbers on the side of the Pot. 503?
            Thanks for the reply. No, only the numbers stated.
            I took the pot apart again and using an ohm meter measured the resistance for the best remaining section of carbon. I measured approx. 153 K along a section which would be approx. a 1/4 turn .......on that basis would a 500k linear pot be an ideal replacement ? (I know that 4 x 153 is nearer 600K but assume that the damage to the track may affect the result a little)
              On an old paper schematic I have (ADS 4 Ground Hog).
              Sensitivity - 25k
              Threshold - 250K
              Ground Bal - 25k 10 turn
              Disc 250K
              There are schematics here on the forum
              Did a quick search
              http://www.geotech1.com/forums/showt...ght=ground+hog
                Sensitivity - 25k
                Threshold - 250K
                Disc 250K
                Did a quick search
                Thanks for the heads up on the schematics. I do have 2 other Groundhogs ....a A2B Gold Hunter and a coin hunter , but, are unavailable at the moment. When I can get to them, I'll open them up and measure the pots......I've modified both a little, if there's any interest I'll also put some pics up . Thanks again.
                David
                  Garrett still had the pots last time I contacted them for replacements.
                  You can use any pot brand you like as replacements
                    Sven,
                    do you have the contact details for Garratt replacement parts. I'm in the UK and assume that the only source of vintage parts would be the US ?
                    I think I may have found the reason that the pots have had their tracks 'over cleaned'. On the PCB where the pot is connected is a resistor, colour coded for 2 M Ohms but measured 1 M Ohms. Perhaps the reduced resistance prevented proper adjustment via the pot and a previous owner tried to repair that, rather than check the circuit
                    Regards David
                      Try Brad at Garrett USA [email protected]
